hmm mine fit just fine...sure ya got the right sprocket???did anyone using the 15t front sprocket have any problems getting the case saver to fit, it seems i may have to grind some of it down to make it fit. if anyone has any solutions please let me know.
thats the one i have and it fits fine on mine. its been on there for over two months with no issuesi got the kx450 dirtbike sprocket from rockymountain, it just seems like the fit will be way too close. what did you use to grind it down?
Good deal, I'll be doing the same.The 15 was great ........ i was only looking for 6th a couple times in the big bowls. I will be going to a 15/36. I think that the 15/36 combo will be perfect for me.
Seems to me that it would just make first gear a little longer wouldn't it? All the rest would just be faster.I just added a 15 tooth renthal front. It fit good and did not rub, but i do have a pro design case saver installed. I will be running it this weekend. i will let you know how it does for me. Yes 3 in the back does about equal 1 in the front. Going to a 15 or going down on the rear sprocket will add top speed and also make each gear alittle longer too.
