QUOTE (esquared @ Jan 29 2010, 02:06 AM)
index.php?act=findpost&pid=18943
Leave in neutral and turn the key off as well as the switch. Mine will drain down if not started for a couple months so I leave it on a trickle charger all the time as I do with my other quads.
Ended up over here because the other KFX forum seems to be down?
Anyways, I have a big thread going over there about this.
Basically what I have figured out is only 2 things are constant...
1- Some people never have a problem
2- The rest of us have a battery drain issue... but the "state" it's parked in that drains it is various.
To those of you having drain issues, try turning your thumb kill switch on and leave it ON all the time.
And try leaving it in gear and in neutral also.
Report back here with your findings.
Leaving the kill switch on works for me.
It is a band-aid for whatever the problem is.
I have some good hunches on what is causing it.
But I need to collect input from more people to figure it out.
(good with problem solving, clueless on wiring)
