just wondering if anyone has a good map for fuel atv intake, pro circuit ti4 comp pipe, power commander 3, kx cams
also was wondering for those who have pro circuit pipes if anyone has changed outlet diameter, the one that they come with is 1 3/8" I orderd the biggest one they make witch is 1 7/8" made a huge difference if you have the big three mods and cams I think the pro circuit pipe has gotten a bad rap because of the smaller outlet that they come with. when you start doing mods for flow the pipe is to restrictive anyone with this pipe needs to order the biggest outlet also if you look at the factory guys pipes thay are using the largest outlet on ther ti4 pipes I have been using fuels map so far but seems like its a little rich so any input would be great. any maps please send to [email protected] thanks
