1 - 6 of 6 Posts
I have problem bolwing the 30 amp fuse under the frount cover. I
in stall a new fuse when i plug the wires in it blows. I thought
i seen a flash were the finders mount to the frame. I installed 4
fuse but no more flash and blowed all of them.
I had tons of fuse problems for about a month or so. All my problems were related to wires that had rubbed on the frame and lost their protective coating. Most of mine were around the radiator area and under the front hood
Check the wires by the starter.. had the same problem and found that the main power wire and a few other wires had been burnt and grounding out
1 - 6 of 6 Posts
