1 - 1 of 1 Posts
I have a 08 kfx450r with a wiseco fuel controller installed. I am having the battery drain issue. I've been reading about the procom ecu as a solution. My question is if I get the procom ecu will I need to unhook my wiseco fuel controller or will they work together on the quad? From what I understand the fuel controller is just a piggy back so basically whatever map you select with the procom will be Intercepted by the fuel controller an adjusted per the fuel controllers settings. So I'm wondering if they will both work together or if I would need to delete the controller? An if they will work together is there any advantages/disadvantages to running both. My thought is if I can run both I will fix my battery drain issue an get some gains with procoms preset maps but still have the ability to adjust on the fly with the controller if need be. New to fuel Injected quads.
1 - 1 of 1 Posts
