QUOTE (450Duner @ Sep 20 2007, 06:27 PM)
index.php?act=findpost&pid=3402
hey moto1 when you added the 6% increase to the map where did you add it to, the low, mid, or high ranges on the PCIII
Thanks!
Yes, all three, with the buttons, read up, find your PCIII USB User's Guide.
Adjustments can be made to the installed map by using the buttons on the face plate of the unit. The buttons divide the RPM range into thirds and will cover all throttle postitions within the specified RPM range. The RPM range can be verified by connection the unit to the computer and powering it up (either with the 9 volt power adapter or the bikes power) While the unit is communicating with the software push the "low" button. The map will be highlighted in the area that the low button affects. Repeat this for the mid and high buttons to verify the ranges. Each light bar change is 2% fuel change over the existing map in the power commander.
TO ADJUST THE BUTTONS FOLLOW THESE STEPS:
Make sure the kill switch is in the run position and turn the ignition on.
within 5 seconds of turning on the ignition press all three buttons down simultaneously.
select the range you wish to adjust; Low,Med,High, by puching the corresponding button once!
At this point pushing the button Repeatedly will move the lights up (richening the map)
(remember each light bar is a 2% change)
After making your adjustments wait 15-20 seconds befor starting or shutting off!
To verify that it is safe to start the bike or turn it off, move the throttle and watch to see if the lights move up and down the scale. If they do, your good.
as you know, if you screw up, or get confused, just download the map you were using and start over, each time you install a map it takes the place of the last one.
one more thing, ( when the two center lights are lit this is the "0" setting (no changes to the base map).
NOTE: While the bike is running the indicator lights on the Power Commander do not indicate rich or lean condition. IN "Button adjustment" mode the lights indicate which way the fuel curve is being adjusted from its baseline. In normal operation the lights only indicate throttle position. At full throttle the lights will not reach the top of the display.
MOTO1
