performance in put
on the kfx .I bought mine in April and ride it in the dunes, and this is what I have done for performance, first off I broke the engine cases the counter shaft broke out of the case, found the chain tension is too tight, after setting it to the factor spec. need to run it looser and a chain slider,
performance to the engine is a Dasa 13" exhaust system, throttle body bored out to 44mm, a LRD programer,dasa grind, web cams mid to top end power also a custom intake system, dyno at 52.7 hp and 35ft lbs torque,on a dyna jet dyno. this set up with a 37 tooth rear sprocket and a 14 tooth front now this is a fast machine, and it will beat any yfz honda or ltz hands down.
