1 - 5 of 5 Posts
just got my kfx back from dealer..they had to replace fuel pump,it wouldnt run after half throttle but done good at idle to half throttle. now it wont run right at a low rpm...it wants to cut out and die...but running at a high rpm it will scream!! anybody got any clues???
QUOTE (kfx450rquad @ Oct 30 2008, 08:35 PM) index.php?act=findpost&pid=13529
Did you try adjusting the idle speed? I noticed on mine that it does not like run well with a very low idle speed. The adjustment is on the throttle body on the left side of the bike under the gas tank.
KT
Discussion Starter · #4 ·
QUOTE (Kawi Fan @ Nov 5 2008, 12:59 PM) index.php?act=findpost&pid=13642
KT
no ijust took it back it to the dealer..will let you know with the outcome. thanks
1 - 5 of 5 Posts
