QUOTE (mxer333 @ Aug 20 2007, 07:44 PM)
index.php?act=findpost&pid=2950
Looks sweet! Max ground clearance and still uses a 19 1/4 shock Im impressed.
Thanks ..... the person that designed these a-arms has been designing atv suspension since the 80's. He is the man. He hand builds and tig welds these a-arms for me.
Might have to look into one of these kfxs.
You will be happy with this kit ...... no question.
How much do the arms run?
The a-arms are $899.99, but i have one kit for $750.00 shipped.
Also looks like the tierod is in perfect alignment with the arms, so is there any bumpsteer?
This is gonna be a long one ....... The tie rods are in the stock locations. They have not been moved. The look of perfect alignment may not be right at the a-arms are max clearance. So they are parallel to the upper tube, but the upper tube drops down to catch the ball joint. The KFX450 starts to get bump steer in the droop at about 8 inches of travel. I would say the first 10 to 10 1/2 inches of travel has almost no bump steer. After that the bump steer progresses. So you could technically limit the travel at about 10 - 10 1/2 and have almost no bumpsteer. My bike is setup for just over 11 1/2 inches of travel and has minimal bumpsteer in the droop only. All bikes have some bump steer. The KFX450 front end design is very good and the bike will work great with these long travel a-arms.
