I wired a switch to my fan so I can turn it on or off when I want or just run it all the time. Seems to keep the engine cooler. Let me know what you think....Good idea or bad idea. If its a bad idea let us know why. Thanks
^+1 didn't think of that. that would be the way to goIsent there a way to wire it to the key so it comes on when the key comes on? I was planing on doing the same thing. Switch would work and having fan on all the time is always a great idea.
If you just unplug the thermostat on the back side of your cylinder then your fan is running all the time as long as your key is on.I wired a switch to my fan so I can turn it on or off when I want or just run it all the time. Seems to keep the engine cooler. Let me know what you think....Good idea or bad idea. If its a bad idea let us know why. Thanks
hey i tried that and it worked but the FI/temp light stays on. not sure i want to run it like that cause then i won't know if it overheats or something. it's good to know that can be done thoughIf you just unplug the thermostat on the back side of your cylinder then your fan is running all the time as long as your key is on.
Could you show me pictures of where that is located?If you just unplug the thermostat on the back side of your cylinder then your fan is running all the time as long as your key is on.
Try wetter water. It keeps it cooler and as long as your stay movin you don't need the fan all that much. If your riding trails then you would but I know when I'm running wide open it never comes on. I also have a 3M sticker that goes on the head to tell the temp and it works really good. Maybe a thought.I wired a switch to my fan so I can turn it on or off when I want or just run it all the time. Seems to keep the engine cooler. Let me know what you think....Good idea or bad idea. If its a bad idea let us know why. Thanks
I run ww and I also ran a switch off the pink wire on the fan relay. If u leave the switch on,it will turn off with the key.Try wetter water. It keeps it cooler and as long as your stay movin you don't need the fan all that much. If your riding trails then you would but I know when I'm running wide open it never comes on. I also have a 3M sticker that goes on the head to tell the temp and it works really good. Maybe a thought.
