most kits you have to splice or cut into the harness very simple i would recommend cutting and soldering your connections you use the wire thats crimped to the bulb housing as you ground then get a set of testers to test for you main head light not the high beam tape that on off i havnt seen a kit that plugs directly in yet you could make it by getting a hold of an extra head light wiring harness!hey guys i just got my new hids for my quad today and was wandering if anyone had instructions on how to wire them up or is they made some for it i got them off ebay.. thanks
if there plug/play thats sweet just test your factory harness so you can identify your positive/negitive then youll be all set black 2 negitive and red 2 positive put the bulbs in which is easier if you remove the headlights reuse the rubber boots you take off plug it all in secure the ballasts under the hood then your done!it came with a bunch of wires and it looks like u just have to plug in the connectors they sent me in and should be able to plug and play but not sure might ask one my neibors to take a look at it see if he nows or not. thanks man by the way i got the 10000k hids by the way. hopfully they look cool we'll see.
when i get them in i will be sure to get some pics for everyone to see .
ya i now jsut talked to ya but ya came with red and black out of the lights and the ballast have connectors on them all rdy i think all i have to do is put the connectors on the lights still. anyway ill have to take another look at them.if there plug/play thats sweet just test your factory harness so you can identify your positive/negitive then youll be all set black 2 negitive and red 2 positive put the bulbs in which is easier if you remove the headlights reuse the rubber boots you take off plug it all in secure the ballasts under the hood then your done!
only see two relays did you move them around too?check it out!![]()
check it out!![]()
