1 - 18 of 18 Posts
· Premium Member
One thing to remember is the dirt bike cams were designed for a 2 wheeled dirtbike with 1/2 the wieght. Not sure if i would just go out and buy the hot cams for the dirt bike until someone tests them unless you got money to burn.
· Premium Member
Well looks like Hot cams will be selling the dirt bike cams as the quad cams too. Here is the scoop as told to me right from hot cams.
The stage one dirt bike cam will be the STAGE TWO quad cam and the stage two dirt bike cam will be the STAGE THREE quad cam. Hot cams is in the process of changing the part numbers, BUT THE CAMS WILL BE THE SAME AS THE DIRT BIKE CAMS.
· Premium Member
Per HOTCAMS
The NOW stage one dirt bike cams
WILL also be the
stage TWO quad cams
The NOW stage two dirt bike cams
WILL also be the
stage THREE quad cams
They will not have a stage one quad cam. They also said tht dirt bike and quad cams will have different part numbers even though they are the same cams.
if anyone knows the performance differences i would really like to know. also is the stock dirtbike exhuast cam recommended or is the hotcam supposed to be better? from what i heard the intake cam will make the most improvement correct? thanks for any help.
cool, i just cant decide on which hotcam intake cam i should get. i wonder how they perform when compared to each other. i cant decide if i should mess with the exhaust cam or just keep it stock. good luck with your order GRIM, i hope you get great results. im sure some cams will make these things beastly on the dunes and track.
QUOTE (wescaster @ Oct 10 2007, 04:19 PM) index.php?act=findpost&pid=3706
If you go to the hotcams website and check under the dirtbike, they list the specs on each cam. Make sure you put the (inc) after hotcams. or it will take you to somewhere you may not want to go.
Larry
1 - 18 of 18 Posts
