i have put on a pro armor and wired my ground to the bolt for the radiator upper mount and the other wire to the red wire with a black tracer. it is on a two pin plug on the left of the wheeler under the hood. it has a white wire and a blue with yellow tracer plugged into it. this is the wire between the stator and the coil as recomended. i hope this helps.Anybody installed a pro design kill switch on their KFX450r. I would like to know how to install it
Holy s#$%!! Sorry to hear that man! Yep, Pingle is the way to go. It just wires right in line with your key switch, 5 minutes and voila. A little expensive, but obviously worth it.I just spent Wed, Thur, Fri, rewiring my entire Quad because I thought that that would work and it didnt, after some practice and one moto it started on fire. DONT BE AN IDOT LIKE ME, GO BUY A PINGAL AND DO IT THE RIGHT WAY THE FIRST TIME.
Here is the one I have (that works great)... I had to grind it a little bit to get the correct angle, but now it fits perfitim gettin a pingel soon 4 my kfx 450 should i get a closed or open switch?
