i need a map for stock exhaust and an ltr intake tube put on.
I assume you have a PCIII on the bike? If so, go to the Dynojet website and download one of the maps for a slip-on with intake. It should be very close and tons better than the ridiculously-lean "stock" map.i need a map for stock exhaust and an ltr intake tube put on.
First off, a borrowed map is not going to match your quads requirements 100%...you will need a custom dyno to have it done properly..With that, you can use a borrowed map that closely resembles your set up, if you are comfortable making changes to the pciii based on your knowledge (the map youve borrowed is too rich or lean) than go ahead, if not just use it as a temporary map until you have it done properly.does anyone else have an a pinion on this?
That should work, it'll probably be a little on the rich side but should hold you over.well i just got a used esr exhaust system for $245 so i guess i will try fuels map and do a little tweaking if i need to.
