I have a couple mods on my kfx like pro circuit full exhaust, fuelatv intake, and PCIII. I have not found any fuel map exactly for my mods but i have experimented with a couple different ones. I used the fuelatv map I got with my intake, but it was for a dasa exhaust. It worked well until i wraped my header pipe with heat wrap. Then after a couple rides it would blow a flame out the exhaust every once in a while, and eventually started cutting out real bad, bad enough to kill it and sometimes turn the FI light on. It would start hard but once i hit the throttle a couple times the FI light will go off, and run fine. It only doesthis when the the engine is warm. I have changed the fuel map a couple of times and it still has this problem. So do you think its the heat wrap or just needs the right fuel map.
If anybody has any info please let me know what i can do, whether it be get a costum fuel map made or maybe take the heat wrap off. Although i dont know how the heat wrap affected it.
