HI Folks:
I'm having issues when I'm trying to start my KFX, It take a lot of time to engine comes up, I'm going to check spark plug, and injector. Sometime I have to pull the chocke start and pull off to start the engine even if it warm. This equipment is EFI, and it has to start fast. Anyone can help???
Thanks
Jorge
You can search around, there is a way to adjust the TPS that will make it easier to start, mine starts fine when it's cold, once warm it take a few seconds longer, the adjustment will fix it
QUOTE (jimmyjames1700 @ Sep 29 2008, 05:50 PM) index.php?act=findpost&pid=12482
Do you use the Fuel Enrichener/Idle Adjust knob on the throttle body when it's cold?
I have never used the knob on mine, I have not had any problems starting it really cold or when its hot. It has always started right up...
