i want more top end do i want to go with more or less teeth on front and back sprocks how does that work
Do a seach on "gears" or "gearing" you can go with a 15 up front (clearly less expensive than the rear sprocket) and drop the rear...theres varied configs but the 34 or 36 in the back seems to run well with the 15 up front...Hopefully you've upgraded you intake, exhaust and added a pciii otherwise youll struggle in the high gears stocki want more top end do i want to go with more or less teeth on front and back sprocks how does that work
im going with the dasa13" can mid and header pc3 and the fci intakeDo a seach on "gears" or "gearing" you can go with a 15 up front (clearly less expensive than the rear sprocket) and drop the rear...theres varied configs but the 34 or 36 in the back seems to run well with the 15 up front...Hopefully you've upgraded you intake, exhaust and added a pciii otherwise youll struggle in the high gears stock
