Thanks duster you have been alot of help. But when you say "Disassemble and grease suspension pivot points periodically" how often do you mean .. once a year?, every ride? And also when I buy the used one (hopefully soon) im going to bring it to a dealer, so I assume they can tell me if it has any electrical problems right? After having it for some time I plan on putting on an aftermarket exhaust (slip on or full system... just not sure yet) but if I do then do I need some sort of programmer because I mentioned it to a kawasaki dealer and they said that the EFI would adjust. They said only if you seriously mod it then it would be needed. What would happen if I put on an exhaust without a programmer?
A lot of guys just take this stuff apart when they get a machine home, even new. Some claim the factory doesn't put enough in the pivots and rear axle carrier. I haven't bothered with it myself. Over the winter probably wouldn't hurt in my opinion.
Some dealers can help you with these... most can't.
Mine couldn't help me although they tried very hard.
So I learned how to help myself.
I can help you with most anything you run into.
Electrical stuff has a reputation of hiding, and then showing up later at random.
Don't worry... save your money... and just ask me if something pops up.
I'll teach you how to find and fix problems if you have any.
(I know what it was like to be on my own with it)
After having it a while, put a full system on it like I have.
They are big bucks direct, but I can show you where to get one for $365.
The stock titanium header is a nice buzz word for sales... but it cracks. So for a few more dollars than a slip on you can avoid that replacement cost down the road... cause you'll have to buy another stocker to keep using your slip on... So for a few dollars more you avoid that and gain the performance of a full exhaust.
Certainly don't take your KFX to that dealer's shop. They are clueless. The KFX does not have any ability to self-adjust for mods. It has no o2 sensor, or mass air sensor. In stock form all it can do is try to compensate for air temp (inlet air temp sensor) and altitude (inlet air pressure sensor).
Most people have been able to add an exhaust system without any problems though. But not because the KFX can adjust... but because the stock mapping is RICH in most cases.
So an exhaust without a programmer just brings the air/fuel ratio closer to spot on.
I would not buy a programmer for a while until you see how good everything is... which means you won't be able to change intakes... but you won't need the programmer until then anyways.
