69.8 MPH on the Garmin Etrex legend is the top speed.
As we all know, everyone says that the KFX450R is geared low. This KFX450R has the most HP in its class and is a fast revving machine. SO please do not be diappaspointed. I am very happy with my purchase. This machine is set up for MX and XC as far as gearing goes. It has a ton of torque to take off and get off the line.
Also, the KFX has amazing handling and power on the track. Its unbelievable and is geared just right. It keeps you only switching between 2 gears while any higher geared ATV would keep you shifting alot. I think Kawasaki got the gearing right. I did some more research and found out the dirtbike has similar compression to the KFX450. 12.0:1 for the bike and supposedly 12.1:1 for the atv. Bore and stroke is the same. The dirt bike puts out the most HP in its class also.
Mostly this engine has low end torque and it great for taking off and going around the track and pulling out of corners. You dont really have lean as much as my YFX450.
And as for the trails, it works the same way. All the torque you need to dodge the trees and pull out of the Corners. The kfx also is a high revver. One thing I noticed is that the YFZ feels like it hits hard and thats cause it has no bottom end so its blah to whoah, theres the hp. While the kfx is whoah to wooter better shift.
My idea is to take 3-5 teeth off the rear sprocket. if anyone has info, please post it. I will be getting the skids this week, a crower cam, power programmer and exhaust. I will keep you updated.
Jeff
Jeff
