I got to test ride the KTM quad setups this weekend and owning a KFX I can clearly state what you all will not like to hear. I'll get flamed either way but wait till you guys test ride one of these things. Dominating power for the 450 class, the best stock suspension ever being Ohlins triple rate LONG TRAVELS, 48" wide that can be 50" w/a wheel change and adjustable rear axle. Chromoly frame, swingarm, fully adjustable front chromoly a-arms, Twin Air filter, grease zerk on tapered roller bearings rear end, 357lbs READY TO RIDE w/all fluids minus fuel in the quad, and the best ergonomics. You can ride the thing for hours on end and not have hurting knees or anything. 3.5gallon stock gas tank, Magura hydraulic clutch, handlebars, brakes, stainless lines, Razr tires on a new type of rolled lip Douglas wheels, etc, etc.
The quad was amazing the the 525 was almost too much to handle. Wheelies in 4th gear are no problem by just punching the throttle. KTM did their homework but w/only 1500 of each model being made, better get that order in. But at close to $9000 it won't be cheap, but well worth it. Ready to race out of the box minus nerfs and a wheel/tire switch for MX. Tons of photos and VIDEO will be available on ATVSource.com later this week as well as the full story so keep checking back.
