will the 2007 dirt bike cams work and is the cylinder head the same and will it fit?
Depends on your build. I ran kx cams last year with the big 3 and a 13.5:1 piston and they worked great! This year I am boring TBody and going to 100mm bore,so I am going to run webbs. Probably 242/216 grindWhat is a better way to go for cams? web cams or kx cams?
Use both!are both the kx cams recomended or will just the intake work?
