Engine:
Liquid-cooled, four-stroke single, DOHC, four valves per cylinder
Displacement: 449cc
Bore x stroke: 96 x 62.1mm
Compression ratio: TBA
Fuel Injection: 32-bit digital, with 42mm Keihin throttle body
Ignition: Digital AC-CDI
Transmission: Five-speed with reverse
Final drive: Chain
Frame: Aluminum double cradle, racing type
Suspension front / wheel travel: Dual A-arms, coil-over shocks / TBA
Suspension rear / wheel travel: Swingarm dual-rate reservoir shock / TBA
Front tire: AT21x7-10
Rear tire: AT20x10-9
Front brakes: Dual 163mm discs with two-piston calipers
Rear brake: 200mm petal-type rotor with single-piston caliper
Overall length: TBA
Overall width: 48in
Wheelbase: TBA
Ground clearance: 7.6 in.
Fuel capacity: 2.2 gal.
Lighting:. Dual removable headlights
Dry weight: 345LBS
Color choices: Lime Green / Super Black, Bright White / Super Black
What Kawi's website says...
Early Release 2008 model- arriving in dealerships early 2007
NEW 2008 KFX®450R INTRODUCES ATV COMMUNITY TO KAWASAKI RACING TECHNOLOGY
Motocross performance based on the World Champion KX™450F
Take the short cut to the circuit with the all-new Kawasaki KFX®450R ATV. This high performance machine doesn’t require extensive and expensive modifications to make it race-ready, because it already includes all the race-winning performance and technology required for success straight out of the crate.
The KFX450R’s design incorporates everything riders need to win races. Every component was chosen to maximize performance on the track or in the woods and to minimize the fuss of getting there. This highly advanced racing ATV comes with all the performance and technology necessary to put riders at the head of the pack.
The KFX450R ATV uses a powerplant based on Kawasaki’s highly acclaimed KX™450F motocross engine. With the addition of an efficient and highly-responsive 32-bit digital fuel injection system, the KFX450R’s engine produces more torque in the low and medium rpm ranges for outstanding hole-shot acceleration. The use of fuel injection helps ensure that the engine’s performance remains consistent and is virtually unaffected by changes in temperature or altitude. This ATV’s ability to find traction is superb, and its four-stroke torque helps keep the wheels hooked-up for improved handling and higher corner speeds. Other race-ready features include a lightweight titanium exhaust header pipe and a durable forged piston.
Winning at the track depends on a chassis that’s built to handle tough race conditions. The KFX450R offers the full benefits of an all-aluminium frame, combining exceptionally light weight with the extreme stiffness needed to win races. However, it isn’t just advanced materials that give the KFX450R its race-winning edge. The front suspension design incorporates extremely long lower A-arms mounted to a single box-section lower frame tube. This results in outstanding response from the front-end. At the rear is a cast aluminium swingarm that provides the ideal balance of flexibility and rigidity resulting in unparalleled traction. The high-tech chassis also features a very low center of gravity and excellent roll resistance. Regardless of changing conditions or rough track surfaces, this race-oriented chassis makes the KFX450R a potent weapon in the battle for ATV supremacy.
Competition-oriented equipment, including the only reverse gear in its class, helps keep the KFX fast and reliable. Previously unheard of in racing, the KFX 450R’s lightweight reverse system lets riders quickly extricate themselves from first turn chaos or dead-end trails. This important feature means on-track incidents (like getting nosed-into a wall) no longer result in an early retirement from the race.
Kawasaki has also made the KFX450R easy to work on, so riders can concentrate on winning instead of wrenching. The two-piece front and rear “lapped” fenders make it possible to replace sections separately if they get damaged. Even the headlight assembly is quickly detachable for closed-course races, and the compact design means that the ATV looks just as aggressive with or without headlights. These features leave little doubt that the new KFX450R was designed to get its rider on the racetrack and winning races as quickly as possible.
Displacement: 449cc
Final drive: Chain
Overall length: TBA
Overall width: 48in
Wheelbase: TBA
Dry weight: 345LBS
