ok heres whats going on. Purchased the quad right when it came out and it worked well for about a week or so. Now every time i go to start the quad, i hear a slow crank and grinding noises. The quad will start after a bit but then once it runs and gets shut off it will do the same thing.
I brought it to two Kawi dealers and had it looked at, the problem was never identified. The battery was replaced twice but still seems to drain. Every battery that was put into the quad seems to fail the load test.The quad is stored every single night on a battery tender with the kill and key off.
The weak start gets worse every time the quad is left to sit without the tender. I was thinking there could be a load on the battery but it's not from the key or kill. The headlights and wires we removed but it mad no differnece. I triple checked all connections and checked for corrosion aswell.
Even after riding all day, as soon as the quad shuts off it is very difficult to start again. The valves were just adjusted, idle and enricher reset, stator and electrical tested ( i have the outputs is that will help). I was told from the dealer that the startor and/or one way clutch might be broken and we are looking into that next.
Any ideas? Anyone having similar problems?
Thanks
Dean
Thanks
Dean
