From Fuel's write up:
Nmotion pipe - 9 inch version
Peak HP -
Max Torque -
114db at 3750
The N-motion pipe is a multi step pipe. It has a thick billet head pipe flange and a trick billet canister mount. The n-motion pipe is available with 2 canister options a 9 inch canister, a 12 inch low db canister. The 12 inch low db canister is $85.00 extra. The n-motion pipe does have a riveted canister this will make repacking the canister alittle more time consuming.
Nmotion pipe - 12 inch low DB version
Peak HP
Max Torque
104db at 3750
The N-motion pipe is a multi step pipe. This low DB version is very trick. The pipe features a titanuim canister and carbon fiber end cap. It has a thick billet head pipe flange and a trick billet canister mount. The n-motion pipe is available with 2 canister options a 9 inch canister, a 12 inch low db canister. The 12 inch low db canister is $85.00 extra. The n-motion pipe does have a riveted canister this will make repacking the canister alittle more time consuming.
