when I changed my oil for the 1st scheduled oil change, I over filled it and it leaked from where the reverse lock out cable goes into the case. I thought it was the shifter seal, but after cleaning the case up with some brake cleaner, you could see it was from the little rubber boot on the cable itself. After draining some oil and getting it to the correct level, it quit leaking. A few days ago I changed the oil again and was sure that I didn't over fill this time. I ran the engine for a few minutes, and then checked the sight window and the oil was about 1/2 way. After a few minutes the oil setteled and completely covered the sight window. So I had to drain some more oil out. The next day, there was an oil spot on the floor under the quad. I looked at the sight window and again it was covered, and the oil was again coming from the reverse cable. Soooooooo I drained some more oil. My question is whether or not the reverse cable should be leaking oil even if the engine is a little over filled with oil? and when checking the oil level I guess the engine should not be started to get the correct oil level reading?
