has anyone painted their wheels yet? i want to pain them black.. if you have, what kind of paint did you use?
I powdercoated mine. If you choose to use liquid paint you need to prep the metal very good. Either sandblast or use 320 grit sandpaper. After its sanded you need to use a wax and grease remover such as prepsol and use two clean paper towels. Wet one towel with prepsol and leave one dry. Wipe the rim with the wet one then dry it off quick with the other one. Now your ready for paint. You will need a metal etch primer. Do not confuse it with grey primer sealer or primer filler. Only green etch primer will bite into raw metal. After spraying the etch primer wait 10 mintues then spray your color right over it. If you have access to automotive spray equipment then you can get the paint in quarts from NAPA auto parts. If your going to go the rattle can spray paint route then you can get duplicolor spray paint just about anywhere. Just remember that its 90% preperation and 10% actual painting to do the job right. I was a car painter for almost 10 years and this is the correct way to do it. Have fun and let me know how it comes out.has anyone painted their wheels yet? i want to pain them black.. if you have, what kind of paint did you use?
Do you have a pic you can post up? Would like to see how it came out.Lol i litterally just Painted my front Rims black yesterday, first i sanded the rims (as much as it pained me to ruin the shiny silver lol) then i cleaned them really good with alchohal then I used normal flat black spray paint, about 4 solid coats. then after those dryed for about an hour i put 2 layers of Protective Glossy Spray on them and let them dry for the rest of the day, they look great i did a scratch test on one and it held up pretty good![]()
ThanksLooks good to me..looks natural, good job![]()
I bought the black "special edition" KFX, so no need to paint my wheels, but a buddy I work with painted the wheels on his 660 Raptor. (We Laser cut a nice fake-o beadlock flange and welded it into the rim for strength first, looks pretty slick) We sanded and cleaned the rim with isopropyl alcohol, and then sprayed them with industrial high solids flat black paint. The paint won't hold up like powdercoat, of course, but we didn't pay for the paint, so we'll just re-spray them when they get chipped.Thanks, i did mess up a little bit but i just got a magic marker and got it
ssshhh![]()
Tks eldridge ! I done it like u said except I used 180 grit . My rims were old n pretty scuffed up . It worked great so far . I've got one hard day at the track slamming them into bike ruts even broke the bead loose once . They look just like they did when I loaded the quad up !I powdercoated mine. If you choose to use liquid paint you need to prep the metal very good. Either sandblast or use 320 grit sandpaper. After its sanded you need to use a wax and grease remover such as prepsol and use two clean paper towels. Wet one towel with prepsol and leave one dry. Wipe the rim with the wet one then dry it off quick with the other one. Now your ready for paint. You will need a metal etch primer. Do not confuse it with grey primer sealer or primer filler. Only green etch primer will bite into raw metal. After spraying the etch primer wait 10 mintues then spray your color right over it. If you have access to automotive spray equipment then you can get the paint in quarts from NAPA auto parts. If your going to go the rattle can spray paint route then you can get duplicolor spray paint just about anywhere. Just remember that its 90% preperation and 10% actual painting to do the job right. I was a car painter for almost 10 years and this is the correct way to do it. Have fun and let me know how it comes out.
i painted my front rims last season and after a year on them they looked like this. thats no prep work or anything. just a ghetto spray job. it holds up fine for fronts. I wouldn't touch your backs with spraybombs
http://c3.ac-images.myspacecdn.com/images0...9b5960db746.jpg
