Check the PCiii wiring, the ground could be loose.starts ok but cuts off from time to time. I have lost power at top end very choppy
Plug is brand new
mods two brother full system power commander
sorry all I have to go on
Also check the TPS wire. Mine got cut by the pc3 wire that you splice to it. I would guess from vibration. Let us knowstarts ok but cuts off from time to time. I have lost power at top end very choppy
Plug is brand new
There is a wire from the pc3 that needs a TPS signal. So you get a cheap connector and splice into the TPS wire. Thats what the installation instructions say.You have to splice into a wire?!?!
