1 - 5 of 5 Posts
Hello Iv got a Pro Circuit T4 full exhaust and the stock air box. On the power commander web site they have a map for it but some of the maps have it for the stock air box lid removed but not for the Pro Circuit?? Will it make much diffrence? I plan to remove my lid so I just wanted to know. If so does anyone have a map for the stock lid removed and pro circuit? Thanks
Intake changes make the biggest differance by far. Run a map with the right intake box setup with any pipe and you should be ok.
Get rid of that stock intake. I bolted on the FuelATV intake with a stock pipe. Really woke up my quad. Huge change in the bottom end power.
Get it dynoed! that is the best bang for your buck
A lot of you guys spend all this money on parts, the most power you can make for your money is to have it dynoed by a good tuner, no two bikes are identical and the maps get you in the ballpark, just an FYI
1 - 5 of 5 Posts
