I was wondering if somebody could help me out by telling me the steps to removing the parking brake. I would like to get ride of the actuall brake in the rear and the whole part on the handlebars. i hope that someone can help me.... also would like to know if once i remove that if i can put on ASV levers
It is very easy. Loosen the lock nut from the adjuster on the rear caliper and remove the cable from the clutch perch. Then remove the two 12mm bolts that hold the aasembly to the caliper, make sure you buy a parking brake block-off plate. Then pull the cable through the bike untill it is completely. finaly remove all unnecessary parts from the clutch perch. The entire job should take about 5 minutes.
