hey would this be the problem with my quad il take it out riding an come back in a couple days an the relay is clicking under the hood top left one an the fuse is good it wont start just click an the odd time when it does this it will slowly turn over then just click my dealer can not fix this problem an im getting very pissed any info on this would be greatfull seeing how im considering switching brands after 4-5 months of owning this peice of crap an im on my second wire harnness 3rd or 4th battarie main fuse an now its been down there for a week an there putting a key switch in it this time
Sounds like you are suffering the simple battery drain issue many of us have.
Next time it does it, check the battery voltage.
Normally, the battery should stay near 13v.
But if you are having such problems it is not likely to, and it will not stop until the ECU is replaced. Kawasaki refuses to authorize warranty coverage on the part though. (I think they fear a recall). So if this IS the case, you will need to do what I did and replace your stock ECU with Procom's fully reprogrammable ECU.
I have not had a problem since.
