1 - 6 of 6 Posts
QUOTE (Renato @ Jun 12 2007, 09:54 AM) index.php?act=findpost&pid=2322
I wanted to change the thubthrottle and make a twisthrottle conversion but i don´t know how to but the reverse buttom. Any one made the conversion already? What is the best way to make this mod?
Get a dr d reverse lever for a kfx 400. It mounts in the same spot except it goes directly on the handlebars.
cool
QUOTE (spencer @ May 15 2008, 02:13 PM) index.php?act=findpost&pid=9043
does the stock KFX450 cable work with the Dr. D lever? I am installing a 400ex throttle on my KFX, and ordered the DR. D reverse lever, going to take the cable off and use the stock KFX450 one if it will work.
Dude, do not buy a KFX 400 Reverse Lever. I tried it was a pain in the ass. DR. D is making a 450 lever soon. Check back with them. A quick lesson on installing when you do get one. Just to the right of the front sprocket on the case. Take a 8" extension and use a 8mm socket and take bolt out. Pull on the whole cable assembly and the plunger comes out of the case. Once you have that out disconnect and reinstall new cable.
QUOTE (nogard @ May 18 2008, 05:02 PM) index.php?act=findpost&pid=9158
I didn't have any problems making it work, had to adjust the reverse cable some but no big deal. I am still using the stock reverse cable. Oh, and the 400ex thumb throttle feels SOOO much better.
1 - 6 of 6 Posts
