I wonder if there is a reverse limiter and where is the switch located i didn't see it
Some quads w/ reverse have an override button on the handlebars so you can get full power in reverse.Does any quad with reverse not have a limiter? Im pretty sure it will... But like every other quad, someone will figure it out...
I know that some of the Arctic Cat utility quads have a Reverse override button that allows you to go full throttle in reverse. It's a little scary though when you hook up though and it shoots you out of where ever you were.thats a polaris only thing I think...
I don't know about a limiter, Just got mine last night. But the lever is right above the throttle. shift to 1st, move the lever to the left and down shift.I wonder if there is a reverse limiter and where is the switch located i didn't see it
