Ya beat me to it! I'll paste them so they don't have to open another window. I don't think 364lbs is bad at all, with out reverse i'd say she's be about 358lbs. Most 250R's were in the 350lb range! Here's the specs for our dial up members!! lol
Engine Liquid-cooled, four-stroke single, DOHC, four valves per cylinder
Displacement 449cc
Bore x stroke 96 x 62.1mm
Fuel Injection 32-bit digital, with 42mm Keihin throttle body
Starting Electric
Transmission Five-speed with reverse
Final drive Two-wheel drive, chain
Frame type Aluminum double cradle, racing type
Front suspension / wheel travel Dual A-arms, coil-over shocks / 8.5 in
Rear suspension / wheel travel Swingarm with piggy-back reservoir shock, dual-rate spring / 10.0 in
Front tires AT21x7-10
Rear tires AT20x10-9
Front brakes Dual 163mm discs with two-piston calipers
Rear brake 200mm petal-type rotor with single-piston caliper
Overall length 71.1 in
Overall width 46.0 in
Overall height 41.9 in
Seat height 30.9 in
Wheelbase 49.4 in
Ground clearance 4.3 in
Lighting Dual removable headlights
Dry weight 364 lb
Fuel capacity 2.6 gal
Footpegs Sport-style serrated
Color choices Lime Green / Super Black, Bright White / Super Black, Super Black
Good Times™ Protection Plan 12, 24, 36 or 48 months
Warranty 6 Months
