QUOTE (nogard @ Apr 7 2008, 12:51 PM)
index.php?act=findpost&pid=7999
My bike is approx. one month old. Prior to putting on my mod box from DR. D, I could of sworn I pulled in the clutch and the bike started every time. Since I putt on the full exhaust and MOD BOX the bike only kicks over when I pull in the clutch and in Neutral. What gives any fixes?
Are you still using the stock battery? The stock battery is only 85cca and won't handle many mods. We switched to the Yuasa YTZ7s (honda 450r battery) it has 135 cca's.
If you hook up a set of jumper cables to the battery off of a stronger battery and it starts then you need a stronger battery.
I'm not sure if this is the problem but it is worth a try. After I switched batterys mine started better and never had any problem with mods.
Also check your clutch cable adjustment. How cold is it? and does it get better when it is warm? What oil are you running?
Hope this helps...Ric
