I'm having issue with this quad starting. I have about 7 hrs on the quad.
When the quad is cold, it takes a couple trys to get it to start. That is with the choke/ fast idle adjustment pulled. Once the quad is warm (5 mins or so) I can turn it off and then try and start it again and it will not fire up. I have the choke off and I'm also trying the ( on/off method) with the key switch to prime the fuel pump. It seems like the intake valves might be too tight?? It will backfire thru the exhaust every once in a while. Now, if I go out riding for a while and stall the quad it will fire right up. However, if I let set for 5 min's or so, it takes forever to get it started.
I talked to Yokley at loretta's this weekend and he said to adjust the throttle positioning sensor????
BTW, air filter is clean and it has plenty of gas..
Here are the mods I have on the quad: Uncorked exhaust, removed air box lid. (uncorked exhaust/removed lid) PC III Map.
