The bottom of steering stem call “Steering Shaft Ball Joint” is absolutely a weak area on the KFX450. I went through (4) of them so far. I am working of a fix but its going to be a little complicated because unfortunately the piece is not rebuildable so I am having it machined to except a floating bearing. Have any of you had any issue with yours?
RJ
# 59266-0026 STEERING SHAFT JOINT-BALL 1 - $81.22
RJ
