1 - 5 of 5 Posts
Trying to remove the steering stem - I can't get the tie-rod joint off of the stem so that I can pull it through the frame. Any help would be great. Thanks
I find two hammers and tap them simultaneously and the joint will just pop out
I am doing the same thing. The angle to hit the ball joint doesn't seem sufficient or enough clearance. If I am able to get the ball joint out will they still be usable or do I buy a new set?
QUOTE (nogard @ Mar 16 2008, 09:02 PM) index.php?act=findpost&pid=7355
put the nut on the end of it and hit the nut it will keep the thread safe then take the nut off once it comes lose good luck
1 - 5 of 5 Posts
