I was wanting to know what is involved in replacing the steering stem on a 2008 KFX 450? mine got bent when it slipped on the ramp while unloading it.
Are there any special tools required? approx. how long does it take to change out?You must take the bars off, remove your front plastic, remove the top clamp, remove the tie-rod ends,
remove the bottom ball joint, pull the stem out through the top, switch out ball joint to the new steering stem,
slide the stem and ball joint back down, put it all back together
No - Once you get the plastic off you can see the top clamp behind all of the cablesThanks for the help, I was looking at it and it looks like it can be done with the front fender on, is there other clamps hiding?
ThanksNo - Once you get the plastic off you can see the top clamp behind all of the cables
I took the plastocs off and gained access to the bop bolts but I can't figure out how to get the bottom bolt off, it seems to be recessed inside the frame with no access, there is another bracket that had I believe is 2 torx head screws and was wanting to know if they need to be removed also?Thanks
You need to remove the two torx screws from the very bottom - you can't get to the bottom bolt until you pull the entire steering stem off of the quad - you will pull the steering stem and the bottom joint out togetherI took the plastocs off and gained access to the bop bolts but I can't figure out how to get the bottom bolt off, it seems to be recessed inside the frame with no access, there is another bracket that had I believe is 2 torx head screws and was wanting to know if they need to be removed also?
I will give it a try, thanksYou need to remove the two torx screws from the very bottom - you can't get to the bottom bolt until you pull the entire steering stem off of the quad - you will pull the steering stem and the bottom joint out together
I already bought the stem,My suggestion is to pick up a stem from Steve at FuelATV or Chad great guys even better service and prices
I am currently working on the steering stem but I cannot get the tie rod end out, it feels like they were pressewd in there, any suggestions? you can e-mail me directly at [email protected]I already bought the stem,
Hit them out w/ a peice of wood and a hammerI am currently working on the steering stem but I cannot get the tie rod end out, it feels like they were pressewd in there, any suggestions? you can e-mail me directly at [email protected]
Thanks, it workedHit them out w/ a peice of wood and a hammer
