i have read that you must calibrate the tps after installing the power commander3 any info on this would be appreciated.
Some do some don't. If you have a hard time starting it after it gets hot-warmed up you probably need need to adjust it. There is a guy on the HQ site that has a post on how do do it. His user name is Moto1,you should be able to do a search for his post and find it.If you can't find it PM me and I will get it for you. He might have it on this site too,I don't know for sure.i have read that you must calibrate the tps after installing the power commander3 any info on this would be appreciated.
<div class='quotemain'>
If I read your post right, you are asking about the calibration using the Power Commander software? If this is the case then when connected to a PC, you can go into the Tools Menu option in the software and select Calibrate TPS.i have read that you must calibrate the tps after installing the power commander3 any info on this would be appreciated.
